As said. The vertical animation does not work on Lucid Launcher. Vertical Wallpaper scrolling is switched on.
Found out now, that it functions somehow but exact settings are not possible. On the edit screen all seems fine but the result on homescreen are all messed up.
Vertical scrolling depends on Launcher support, if the launcher does not support Vertical scroll properly it wont work on KLWP. There is nothing i can do to fix this.
