Variable Rotation
Hey, it would be nice to be able to automatically adjust the rotation depending on some variable, like the sunset or similar. For now I can only put in a number manually.
You can add the formula that you want
Rotation:manual
tap in the square in the right of the number of rotation, this are going to open the formula editor, and add the formulas that you want.
