I need to find the .klwp file which is the one thats autosaved but i cannot export the preset i need the autosave file so i can back it up there is a autosave folder in the kustom folder but it only has kwgt files i spent alot of time on the klwp preset if anyone can help me please tell
As far as I know, the autosave folder contains only KWGT presets that are/were used in the homescreen.
Additionally, autosaves do not capture complete resources like an exported preset does.
