Update Mode
Been a long time user of Kustom and im asking this as a widget maker to user.
Basically im making some Widgets for a buddy who is going to release an icon pack.
One of the widgets is an analogue clock which shows the seconds hand moving along with physical numbers ticking per second. For this to work you need to set your Update mode to “Fast”
Do most users use this setting normally? or are you happy to change the setting if your interested in using a clock or item dependent on the need of per second updates?
I think most users are not in “fast” mode, as of now there is no way to include some notes on the preset that will be shown on load, I need to add that capability
OK thanks for that Frank.
Apricate your comment.
