I thought that it was some memory permission problem introduced in the new beta (I’ve read this topic No storage permissions - #5 by N_Valo) but even installing an older version it doesn’t work anymore!
You can try re-importing the preset. If the issue persists, you can do a clean install using the steps from the link below. Make sure that you have everything exported and backed up before you proceed.
I’m having a similar issue. I made my own taskbar with icons based on tasker variables, as well as an automated wallpaper switcher and both stopped working for me today. Galaxy S21 FE on Android 13 here. 5.1 OneUI still.
Kudos! This is the way (cit) OR you can use flows, by triggering a flow via formula and then setting an image as a global, this would work on any folder although might be a bit more complex
I thought it might be the storage permission issue, so I put my files in the Kustom folder and that didn’t work. I hadn’t tried changing the path from “storage/emulated…” to “file:///Kustom//…”. I’ll give it a try! Thank you.
