Transform integer number
hello.
i wanted to know if its possible to add this feature under math utilities section.
transform integer number into decimal form.
i mean like this : 2 ➜ 2.000
i wanted to make a formula.that needs the third char.all my numbers are decimal except the first one and this breaks the pattern.
1 , 0.1 , 0.2 , 0.3 , 0.4 , 0.5 ➜ 1.0 , 0.1 , 0.2 , 0.3 , 0.4 , 0.5
thanks.
If all your source values not exist 3 floating points, Try use
$mu(round, your_var, 3)$
otherwise it will round up/down the values.
