Hi,
i have an basis gv called TabNr and seperate components.
Inside this components touch event should change the TabNr to an specific value. This is generally working.
But if I try to use component variable instead of an specific string it will set to nothing. If I use an basic gv it will work.
Did I anything wrong, or is it not working with component variables.
Alternatively i tried with the mindex formula which is also not working.
https://help.kustom.rocks/i1979-set-global-variable-by-formula-on-tap
Greetings,
Marcus
