Touch not working with KLWP
Touch to open apps / shortcuts are not working.
I have a TCL nextpaper 50 phone and running Nova Launcher
Checked all the permissions and enabled use direct touch but still won’t work.
Sent the file to someone else and works fine for them.
Any idea? Thanks
Have you tried another KLWP preset, just to make sure whether it’s an issue with the preset or the KLWP or the Nova Launcher settings, or even the phone.
:smiley: :+1:
Hi. Thanks for the reply. Yes I’ve tried another preset and same. Guess it’s the device itself.
Many people in the /r/kustom subreddit are reporting the same issues with the latest releases of klwp/kwgt. Rolling back to an older version has worked for some
https://www.reddit.com/r/kustom/comments/1h4ybfs/kustom_has_for_lack_of_a_better_term_completely/m03a8w9/
