Tapping on elements should bring up their details instead of having to navigate through all the menus to find the element, icon, text, color, position, or whatever you want to change
This would be fantastic.
Could be tricky though. Object, parent group, grandparent group, object order preference?
I suspect much of this is also covered by touch detection but, while great, it is sometime flaky between saves.
Also then, for an object with touch actions, do you activate or show properties?
