There's a persistent animation ripple on shapes when you add touch actions in KWGT. This can't be turned off as far as I know. KLWP doesn't have this.
Is this animation normal behavior? If so it should be optional and the same for both KWGT and KLWP.
Thanks in advance,
frank
2
This is normal, its the default background in Android, turning this into a feature request for future implementation
it would be nice to customize the ripple effect when touch as a round shape button with square ripple when touch was not nice to see XD.
Any chance of getting a ripple touch effect natively in KLWP?
It happens in KLWP too. Can you change the ripple color alpha to 0 if there's no way to disable it?
