Tomorrow Weather showing N/A
The “Tomorrow” forecast icon has been showing N/A for the past two days.
I checked, and all of the other future days work just fine.
Test with a different komponent or preset to know if this is an issue with the data or just with the preset. Also, try changing weather provider and see if that helps.
It looks like it was bad data for two days, because today it showed
Today’s Weather as N/A and Tomorrow as actual weather data. My assumption is that the bad data should be cleared out by tomorrow. Thank you!
