Toggle Global Switches Not Working Correctly
Hi,
in KWCH I defined 3 Global Switches sw1, sw2, sw3.
Via tap on circle slices I want to toggle them.
Problem is, that always the same global switch is toggled. E. g. on tap action of slice 2 I defined to toggle sw2, but it toggles s3.
W03.kwch (510.9 KB)
Solved it by replacing the Circle Slices with other form. Seems that slices overlap each other, so the last slice 3 is touched when hitting slice 1.
