The 30 second rule and adding widgets to home
For those starting out the widgets have a default 30 second refresh.
When adding a previously saved widget, or new widget you intend to add a previously saved kompoment, remember this.
Add your widget to the screen, resize as needed then wait 30 seconds before tapping for edit mode.
This should eliminate layer scaling voodoo joojoo.
