Text line wrapping and vertical komponent sizing
I created a simple at a glance widget. Sometimes the event is 1 line sometimes 2. So I set max lines to 2. So when the event is 2 lines widget looks good. But when it is only 1 line there is a gap between the event line and the time of the event line. So is there a way to make the event line grow and shrink vertically to eliminate the blank space?
That is standard text padding there should be no difference on that when its one or two lines. I assume you are using a stack group and placing your text on the stack. You can also try to condense the text in the same text item.
So embarrassed!! Now to look for that tutorial on stacked groups
