TechTips • 🌤️ Do Kustom apps provide their own weather forecast data?
No, Kustom apps do not generate or provide their own weather forecast data.
Instead, Kustom acts as a processing and display engine that fetches weather information from external third-party weather providers (such as Weather Underground or Dark Sky) using your device’s network connection.
Key points regarding weather data in Kustom:
  • Selectable Providers: You can choose your preferred weather source in the app settings or install the Kustom Weather Plugin to access additional external providers
  • Check Active Provider: You can display the name of the current external provider using the formula $wi(provider)$
  • Custom API Keys: Depending on the provider chosen, Kustom allows you to use your own personal API key or subscription (e.g., for Weather Underground)
