Hello,
Since the last version of KWGT, on Galaxy S25, the touch action to call a tasker shortcut task doesn’t work. The shortcut is not saved.
On the old widgets (old version of KWGT), shortcuts already saved work. But If you try to modify it with another shortcut, it doesn’t work.
Could you check please ?
Thanks
Hello,
Nobody to test on OneUI 7 ?
Thanks
Very good support, thanks ![]()
I’m having this issue as well, and I just updated to one ui 7 on my s21. Additionally, I have one task that taps on my screen with autoinput. It now takes over 3 seconds to trigger
Check if version 3.78 is already available in the Play Store for you and see if that helps.
Version 3.78 doesn’t help.
It is a kustom issue, other apps (like Panels) can create tasker shortcuts without issue.
FYi, an alternative is to launch tasker task by uri:
tasker://assistantactions?task=mytask&par1=mytaskparam
Hello,
Is this where bugs are taken into account? Because the lack of response is striking; we have absolutely no idea where we stand or whether our issues will be fixed.
Thanks.
I don’t use Tasker, instead I use Automate. And I test on adding a touch action to trigger an Automate shortcut (Automate shortcut is called Flow, so please don’t confuse with Kustom’s Flow). I use an Automate flow for voice command.
The touch action works well, it runs the shortcut without any issue.
My KWGT version is v3.79b514613 , and as a note, I do not use Samsung Galaxy phone, I use Xiaomi phone. Also, I use the Nova Launcher.
Here’s a screencast of my test on Launch a Shortcut
I guess that the issue you have is related to either one of these:
- Tasker app: settings, shortcut, command, etc.
- OneUI 7: settings, support, etc.
- Phone: settings, permission, etc.
TIPS
- Try to upgrade your KWGT to the latest version/build.
Came here to say this issue is still present in v3.81 and the open URL “workaround” doesn’t work.
