So when i tried to apply wallpaper in KLWP, when i tap “Apply” and “Settings” it won’t do anything. I’m using kwlp 3.76b422110. Here’s an example https://youtu.be/kQa9ncayc50
The Apply and Settings button appears to be a system-level prompt and not from KLWP. Can you apply other live wallpapers just fine?
Yes i can apply another live wallpaper just fine. Only KLWP Wallpapers that i can’t apply
Can you try a different launcher and see if that makes a difference? Try Nova Launcher.
No difference i have tried Nova Launcher and Pixel Launcher, and Total Launcher. Seems like my phone is the problem. Thank you for the help
This is quite strange, are you able to provide any log? Ideally i would need a bug report as explained here → Create a bug report | Kustom HQ
