I have searched a lot but couldn't find this issue.
Phone : Moto G5 Plus
Android Version 7.0 (default display size)
Launcher :Nova launcher default setting.
I have created a widget containing 5 rectangle each same size in stack group(horizontal center) .
Height= $si(rheight)$
Width = $si(rwidth)/5$
Result widget left space at left side.
If i change display size(from android setting) widget looks fine.
frank
2
What do you mean with "if i change display size from android settings" widget looks fine?
Pure android comes with option to change display size. Check screenshot.
https://i.imgur.com/PBvITcL.jpg
https://i.imgur.com/hu1YesD.png
With default display size here is result.
https://i.imgur.com/8a9AT4q.jpg
https://i.imgur.com/5tkucwA.jpg
With small display size
https://i.imgur.com/rkYvGFv.jpg
https://i.imgur.com/mR7fkLA.jpg
