Hi,
I'm sure the answer is simple but nothing I have found suggesting to add a space seems to work.
Here's my code, I would like a space between network name and speed.
Tnx for the help
$if(nc(ssid), + nc(wsig),(nc(operator), + nc(dtype)))$
Hi,
Tnx for the help
Ok my code is not working as well, I'm looking to have wifi or cellular show, depending on what I'm connected to. Can that be done?
For now it just shows cellular info even though I'm connected to wifi.
Thanks for any help.
