Slider bar to adjust parameters
It would be nice to add, as an element, a slider bar that can adjust volume, brightness, change global variables and so on.
I think it can be done by adding a new touch mode, like slide, that will trigger when the element is pressed and moved in some direction.
It's such an important feature for a widget, I hope it can be implemented.
You have company :) I'm looking for this function too
