Shapes aren't alligned correctly
On some of my previous presets I had some "pixel perfect" problems, when sometimes connected shapes didn't combine perfectly. I had to adjust manually padding by 1 pixel or so. Now I found an easy way to reproduce this problem:
- add rectangle,
- position anchored to centre,
- width and height set using si functions to fit the screen,
- stroke set for 1 and 2.
