Shapes all have the same blur level
Every shape in the theme has the same blur level, even when they have different blur settings.
Only tested with shapes in the root for now.
Are you blurring the background or a specific image? if its an image, is it different across shapes?
I'm blurring the background. One shape on top of the screen and one on the bottom. The blur level is always the one with the highest value.
This is not a bug, Kustom is currently not able to keep more than one blurred version of the background in memory, so it will just use one blur level across all shapes if you are blurring the BG more than once
