I want to put both of my parent KUSTOM File 📎 folders as the same file 📎. (LIKE IT USED TO DO) Ever since this last major update there is now a folder 📂 for KLWP and another one for KWGT! I Can't use the fonts I put in KLWP in KWGT without copying and pasting them in the other folder 📂.
In the app settings you can select Kustom root folder, you must have selected a different one for one of the apps, just change it and ensure its the same for both.
