I am trying to create a widget in KWGT. The color of a shape needs to be updated depending on the time of day. I followed your tutorial "Change color based on a condition" on this but in the Paint section I couldn't seem to find the formula icon. I am not using pro. Can you help?
You need to tap in the square right in the color, when ticked, in the top right of the editor tap in the calculator, this open the formula editor, when you finish, tap in the tick in the top right of the formula editor to save the formula.
Thanks for the help! My widget is now complete.
Good one!!!😁👍
Your next step, when you want and you can, is buy the pro of Kwgt or Klwp(with animations options) and you can save and reload your creations when you want.😃👍
