Seconds progress bar editor problem
Just look at the video:
https://www.dropbox.com/s/ly59pe5zzrj23k0/2017_04_13_14_33_23.mp4?dl=0
Maybe this could be a hint for you Frank about the tabs showing randomly. This one is very easy to reproduce.
Wow thats bad, i cant reproduce it however, will better check,does it happen with progress only?
Here https://www.dropbox.com/s/u94ot55gtyv3wex/progress_bug.klwp?dl=0
I found it today, and was able to reproduce it. But this kind of stuff also happened in the editor on other elements, but it happened randomly and I couldn't reproduce it, so didn't report :)
I think it has to do with seconds, I've just added a simple text field (which is by default hhmmss) and the fields in the editor started to mess up same way.
