Screen Orientation
So I've been using KLWP for a while and I love it! The only problem I have with it is Screen Orientation because when I rotate my phone the elements on the screen update in weird places and then the whole preset is messed up. I have to go into the advanced editor and hit save to reset it back to normal.
Is there any way to fix this?
I've attached a screen recording to show what I mean.
Thank You!
Can you share the preset?
How can i do that do I just create a new post?
I am having the same problem
