Hi, my clock is not refreshing as set. It’s always a few mins behind and I have to force stop and clear cache to get it back in sync. I can’t fix the fitness data as well. Phone is pixel 8 pro with android 15. Any advice is appreciated. Thanks.
Same here. Pixel 8 Pro
First, make sure to remove KWGT from your device’s battery optimization. After doing that, go to KWGT’s app settings >> Notification >> Notification Mode - set this to Automatic or Force.
Have tried clearing data, cache and reinstalling, but still the same. Could be incompatible to Android 15 as that’s the last change.
Can you go to the app settings >> Notification >> Notification mode - and set this to Force?
Can you try to set the widget update mode to Fast and see if that helps? To do this, go to KWGT’s app settings >> Advanced options >> Update mode - Fast.
Can you try to grab the latest build from the link below and see if that makes a difference?
Just to update. I reverted back to 3.76 version and everything is working fine now. Refresh is working, fitness data sync is working, everything seems back to normal.
That’s odd. Did you use version 3.76 from the link below? Play Store shouldn’t be able to update sideloaded apps.
Yes, downloaded 3.76 from the link you provided.
