Reading display toggle on miui . What touch action do I add?
Hi, trying to make a switch to turn on my reading display function. What action do I apply to the switch ? I'm on poco f1 .miui and the settings is in display. Is this possible ?
Thanks
Raj
I don't think that you can set this in Klwp. What maybe you can make is a task with Tasker and relate it to a touch in Klwp.
Thanks for the reply. Will give Tasker ago.
Cheers.
