Quick question about character limit on text element
Greetings everyone,
Does anybody know how many characters can be inserted into a text element in the Kustome preset?
I am trying to insert a long text into a single text element, set the element to allow multiline, but it seems that there is a limitation on the length of the text.
Thank you for any shared information.
:smiling_face:
I’m not sure, but that’s easily tested by just entering 1234567890 multiple times until the text gets limited and then count the number of times a 0 is shown (times 10) + the number of digits shown after the last 0.
Nice trick, RonC.
Thanks.
I calculated the amount, but there is severe lag at this number. It is over 50,000 lines of 25 characters
##########################00
These are the characters I used and the grand total is approximately 1,250,000 characters, depending on which ones since they have different widths.
Thank you for experimenting on the character count. :pray::smiling_face:
I was trying to load a song lyric but somehow it got cut after a certain number of lines and characters.
Can you share the wg formula from the Kode Editor?
I just use the $wg(mi(title), txt)$ function to retrieve the lyrics from the text file.
