There's a problem in setting progress bar parameters to CUSTOM and setting Minimum limit to 50 & Maximum limit to 100. Any Level above 50 will show the progress bar as filled up. I was trying to make split music progress widgets but the other bar (50% to 100%) just fills itself up once it hits 50% Level. The 2 progress bar widgets are under a stack group.
Fixed in 3.30, a custom with mimium at 50 set at level 50 should be at 0%
Thank you for fixing it right away. I'll be waiting for the update to be pushed now :)
