Progress bar doesn't work with Eleven music player
The default music player provided with Cyanogenmod and most other ROMs based on Cyanogenmod is Eleven. But the progress bar doesn't show playback time for the player.
This is likely a player issue, is the player available without installing CM? If yes i can try to see if there is any workaround i can implement.
You could sideload it
