Problems With hourly formate
Hi all,
Can someone give me a little advice how to change the result of
$if(bi(charging) = 0, "unplugged", "plugged")$ $tf(bi(plugged))$
to always HOURS? In case the result is bigger then 23 hours or only says "1 day, 2 days and so on...".
Eventually the formula itself can ne reduced? I only need the amount of hours(!) since last unplugging (to see how much is the time of usage up to battery Zero ;-)
Many thanks in advance
Klaus
