I want to make a one-screen-theme. Therefore I have a space in the middle of the screen (S8) where 6 objects are placed in the same place. I have "buttons" on the side -one for each object.
I want to touch a button that the actual objekt fades out and the object, the button is for, fades in. Therefor I have made 6 globals with touch-function and there toggle global switch and then the name for the 6 objects (office, contact, weather, media, calendar, system).
For each object I have made 6 animations: the first one to fade in (when the global switch is used) and the other 5 to fade out the other objects (also with global switches), that it is equal, which object is shown (every shall fade out except the new one I want to show).
This does not function therefore there must be somethin I do not understand.
Thank you very much for any help.
P.S. I use the nova in free version (or do I need the Pro?).
