Pro key Corruption
Hi
I purchased a pro key for Kustom Widget Maker from amazon app store and had to format my phone today.
I re installed it from playstore and then installed key from amazon but it keeps saying its corrupt and i need to uninstall it.
Any solutions? Paid for it but no longer can use it.
Thanks
Unfortunately Amazon Key works only if you also install KLWP from Amazon store as well, if you want to swap your Amazon Key with a Play Store one just send an email to [email protected] with order detail.
