Pixel 9 pro Xl
I have a bunch of Kustom Wallpapers I love, but they don’t display properly on my new Pixel 9 pro xl. I’m sure it’s because of the changed proportion of the length and width but I don’t know how to modify the files to make them work. Can anyone help me?
You could try editing the wallpapers in MS Paint and resize them to the size needed for your new phone. 1344 x 2992 I believe it is. You could also go here Image Resizer | Resize Image Files Online and resize there. Hope this helps :blush::+1:t3:
Thanks for your response!
It’s not the image that doesn’t display correctly - all the buttons and widgets etc are not in their proper position - can someone help? I use Nova launcher.
Same phone. In the root folder, go to Layers. You’ll find Scale +/- there to mess with. You might find that does the trick for you.
Thanks! I’ll give it a try!
