Painful formula
Ok. This one's gonna be painful, so I am 100% OK if you can't do it or it's not possible.
So, when you go to the link https://profiles.google.com/, it redirects to your G+ profile (if you're signed in, of course).
So I was wondering... Using wg, could you get the redirect link? So I would want https://profiles.google.com/ to turn into https://plus.google.com/104277530569445223536 (my G+ profile link) using wg.
Again, 100% OK if it doesn't work. Thanks!
Unfortunately this is not possible, not because Kustom cannot follow redirects, it does and thats not a problem, the issue is that Kustom is not logged in into your Google account so that URL will NOT redirect into the profile one. Kustom currently doesnt even have the permission to read your identity.
Okay! Understandable. Thanks for your time.
