Hello, on my Samsung Galaxy Z Fold 3 (SM-F926U), after the Android version 15 upgrade, the KLWP (Version: 3.78b512316), touch Kustom Action, Open Notification, Index 1, isn’t working. Is it just my phone or does anyone else have this issue as well? Is this fixable? I tested in KWGT as well.
CMIIW, but the Open Notification works on any existing notification. If there’s no item in the Notification Bar then it works but it doesn’t do anything.
Thanks, items are there in the notification bar, I’ve even imported Brandon Kraft’s “Cancellable Notification Stuff” Komponent, it doesn’t work either.
I am facing the same problem, it seems a problem of this version that was not fixed yet. Go to previous version.
