Nova widget to Komponent
Is there a way to import a Nova widget to KLWP?
You can copy/paste elements, but I don’t think there’s a way to properly convert the entire thing directly. You can rename the .kwgt file to .klwp and move that to the “wallpapers” folder. That might work for some themes that don’t have elements specific to KLWP like animations, but there will definitely be a lot of adjustments.
