Previously I had a note 9 with klwp pro and used Nova launcher and found a lot of awesome wallpapers. I never use nav bar and most of my favorites have some built in low on the screen and use gestures. Now on the note 10 plus most of the transferred wallpapers won't allow me to touch the lower buttons. The only solutions I've found that work are either turning on nav bar if it's a global option or tediously moving every single piece up enough for the touch to register. I'm wondering if you have any solutions for this or any ideas because moving every little piece on every wallpaper is a lot of work and usually ruins the entire look. Appreciate the time and any help you can give would be great. Also really love the work man been using this app for a long time and it's awesome keep up the great work.
