Not adjusting!
I have recently started using fluid nav bar which hides the stock nav bar off my home screen. Because of this none of the items on the preset adjust to this. And it doesn't look nice at all. Please help!
Hi👍 Klwp don't have per se the option to adjust automatically, this is on the preset designer to make presets for different screen ratios and, with or without the navbars or others. You can see if in the globals you have this option(made by the designer), if not you can contact the designer and ask him if he have or create this option in his preset. If the preset is unlocked, you can try to adapt the positions of the items at your like.
