Im using mi9, after i update this miui to 11.0.6. every time I tap/click the widget, it doesnt effect/change anything, nor enter to kwgt app.
Please reply, hope to get some solution.
Ali, from Jakarta.
Ali, from Jakarta.
same with me, pake launcher apa bro? aku pake launcher nova gk keluar apa2. tapi pake miui bawaan muncul.
the problem is, miui launcher is boring. but nova prime seems look crash with kwgt
Thanks, really solves the problem.
Udah bisa gan, coba klik link yg di atas.
Ali Yasin,
You are welcome👌
solved makasih bro
thx, its works.
