Next sunrise/sunset time in HH:MM format
Hi, I'm trying to get the time (hour and minutes) format, like "tommorow's sunset will be at 18:45"..
Can't get it to work... Any ideas?
Try this
$df(hh:mm,ai(sunset,a1d))$
That did it! Thanks!
Can I bother you for one more thing? :)
Could you help me out with figuring out how to make a progress bar, that will fill up according to the nezn sunset time? :))
Hi Dor๐Ÿ‘ What is your idea?
I have one that advance from sunrise to sunset, is something like this?
That could work too I guess...
I was thinking of one that's, I guess, could say sunset-to-sunset.. and the level value should, somehow be "current" time I guess.. and the "min" will be the last sunset time, and the "max" will be the next sunset time... Right? ๐Ÿค”
Ah ok, ๐Ÿ‘ I'm going to figure out how to, you are traveling from the yesterday to tomorrow sunset in the same day, this need some if conditions to work(if I can make it work๐Ÿ˜๐Ÿคฃ)
Hi Dor๐Ÿ‘ here you have a komponent, test it and see if work like you want.๐Ÿ‘
https://drive.google.com/open?id=1qPC61Ft5l_RnNUnbYbZVBjAV0W_TFy60
Thanks! Tho, I press the link, it says file not supported
Never mind, got it.. will try it soon, thanks!
Nope.. sadly it doesn't seem to be working.. progress bat stays on full white color all the time.. number don't seem to be changing as well.. :(
You are in your night, yes? jajaja I'm in day here, I need to test and review in the night, is complex the conditions that you need like I said because the travel to one day to another๐Ÿ‘๐Ÿ˜
Try putting the section in 100, actually is in 10, I make a mistake and don't changed this. In 2 hours I can test the night and see how it's work, but make the change and see how work.
Hi Dor๐Ÿ‘ test this, I'm a little bussy to test it, but I think this can work
https://drive.google.com/open?id=15WDQJEYkpahFlkyjj2eBuvZUu7c6Isvm
