Next alarm time not reported correctly
Strangely this used to work on the same widget for about a month and now it always shown my next alarm as x:59 where x is the hour right now.
Even when no alarms are set.
I'm using timely alarm clock
I have a similar problem with my P30 pro.
The widget worked fine for a month and now it shows XX:59
Reinstalling KWGTpro and clearing cache did not solve the problem.
Sorry, I've just discovered it was due to "reliable alarm" setting on Tasker. Turning it to 'never' solved the problem with KWGT....
