Newbi Question please
How do I prevent from the KWGT editor open when I tap on one of the widgets on the home screen…?
that would depends on widget but if widget is simple then you go to touch tab when you’re in root you should be able to see touch action (“Single”) which has “Kustom Action => advanced editor” touch it then again touch on “Kustom action” and select “None” which is very first option in list dialog.
