Network refresh automated switch
Hello,
This one should be simple, but if not possible, should be simple to implement.
Is it possible using KLWP's beta feature, Global formulas, to be able to automatically turn off on an RSS update?
So if the RSS updates, global switch "X" should turn off if it's on. Otherwise, it's manual.
Thanks!
This is not possible, if you want this to be added request a feature through the ideas forums
