Nested if-then-else
More than 4 or 5 nested if-then-else is tedious
Can't we imagine a function that looks like this :
$ (ON gv(Number), value1, value2, value3) $ ?
(Number=2 returns value2)
Hi,
although it is not exactly what you are suggesting, but $if$ already supports multiple conditions, see: https://help.kustom.rocks/i2566-if-if-conditions-if-then-else-support-with-multiple-boolean-operators
For example,
if(
gv(Number) = 1, value1,
gv(Number) = 2, value2,
gv(Number) = 3, value3,
"All other cases here"
Thank you for your suggestion of using IF / THEN / Else which I knew,
3 occurrences are no problem, imagine the readability of 15 or more values. In this sense, the most elegant solution I have found is the use of:
Gv (list, gv (number)).
Gv (number) being the index of the list. Index zero must be the first number, otherwise the 1st element of the list is skipped.
However, the function I proposed avoids the creation of globals.
To be continued if the votes are numerous.
