Widget is simple at best but i want to Differentiate the holidays with Pink colour and also if current day is holiday the colour should be White bit circle should be pink.
Also how i can change size mode from scale to Width & Height? Since i want to fit the as much as possible in limited space of widget. There must be a workaround.
