This is an everything widget. Feel free to use, disassemble, reverse engineer, tidy, improve, tinker, etc . It’s designed to be different and beautiful in an awkward way.
In function, the clock takes a little getting used to. It always centers on the zoomed hour but the dial center is the gold crosshair. The minute goes around the hour, which makes more sense than a separate minute hand (if you really try).
The battery status is self explanatory as is the wireless strength readout.
The sky dial is a 24 hour clock showing night/day, bihourly weather, moon phase. The red line is when the moon will be in the sky.
The code is probably sloppy by some standards and has developed over years. My most recent trick?hack? is to make stuff follow arcs by turning shadow on and adjusting distance and direction.
Anyway.
