Music Player Not on Preferred music player
So I recently updated my KLWP, and after awhile, I noticed when I play music, the wallpaper music controls no longer works, I first checked the formula and there’s no error. But when I checked the general setting my music player no longer reads even though it does on the previous version. My music player is Outertune
The preferred music player list will auto-detect music players that are compliant with Google’s music player standard. If your is not listed, @frank may be able to manually add this for you.
Oh, ok, so should I make a request for the addition of my music player? But it did work on the older version of KLWP before I updated it.
You can submit a request and also consider reaching out to the developer of the music player app to check if any recent changes to the app might have caused them to be removed from the list.
They Added back player resumption. It seems that there were bugs that disabled it. Thanks though.
