Music controls not working
I've installed Powercard XUI. But I cannot play/pause or change the song
Same happening to me. Using a komponent I've used previously but it no longer reacts to previous or next, only Play and Pause. I use Pi Music Player and haven't had a problem with it before now. I'll try tomorrow using Google Music Player, and update if there's any change.
Hi! So in order to ensure Music works please check the following:
  • Kustom has access to Notifications (it should ask you when you save)
  • You started your music player at least once (Kustom detects automatically the player being used)
  • Ensure the Player properly shows a Notification
  • If cover doesnt work ensure your player (Poweramp for example) doesnt have an option to hide the cover in the Lockscreen
  • Try to reboot once, this sometimes is needed when Kustom is upgraded (you can also try reinstalling worst case)
  • Some player might not work, in most cases this is related to the player not implementing Android standards (usually test can be done with Google Music which is fully supported)
Thanks!
Thanks for the info Frank. Google Music wasn't functioning correctly either so I rebooted the phone again and then everything was back to full working order!
